Discussion forum
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz. |
Poly line seeep prob |
Post Reply ![]() |
Author | |
2JimB ![]() Newbie ![]() Joined: 08.Sep.2011 Location: Australia Using: Autocad 2010 Status: Offline Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 02.Jan.2021 at 08:23 |
Ive been trying for hours to turn the attached into a poly line so I
can sweep. Ive done similar quite often previously ... dont know what Im
doing wrong. The files attached. If anyones willing to let me know how to rectify Id be grateful. |
JimB
Its a 3D line.. |
JimB
Vladimir Michl ![]() Moderator Group ![]() CAD Studio a.s. Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 1817 |
JOIN and then SPLINEDIT > Convert to Polyline seems to work fine.
Vladimir Michl (moderator)
CAD Studio - www.cadstudio.cz - Autodesk reseller |
Thanks Vladimir, Ill give t a crack.
much appreciated. |
JimB
I didn't have any success with that process Vladimir. It keeps resisting any join on the bottom line connecting the 2 virticle bent lines. I don't know why ?
Its a 3d line Vladimir. |
JimB
I have tried that on AutoCAD 2021 - maybe its JOIN command is more tolerant to entity types.
Yes I found it ... id never used that before 'join' did the manual join then converted to a poly...sucessfully. I still dont understand why modify object to a poly cant work ... anyway. got there. ta.
JimB
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,031 seconds.
