Discussion forum
CAD discussion |
Undo and Redo not working |
Post Reply |
Author | |
Vladimir Michl
Topic: Undo and Redo not working Posted: 23.Jun.2022 at 18:20 |
You may have your UNDO system switched off - see the UNDO Control command.
Vladimir Michl (moderator)
vjbz
Newbie Joined: 07.Mar.2013 Location: Canada Using: AutoCAD Electrical 2022 Status: Offline Points: 5 |
Posted: 16.Jun.2022 at 19:52 |
Solved:
1. Open the CUI by typing CUI in the command bar. 2. Find Quick Access Toolbars. 3. Remove "Undo and Redo" commands from the Quick Access Toolbar. 4. Added "Undo and Redo" commands back again in the Quick Access Toolbar. Done! I believe these two commands were corrupted along the way, somehow. |
vjbz
Posted: 16.Jun.2022 at 18:34 |
Hi, every time I open a new drawing or click the AutoCAD icon, the undo buttons are grey out, I can turn it on at the command bar. But when closing autocad and open again, they are grey out again. I draw a line or something, delete it and no where to click undo due to button is grey out.
Please help, thanks in advanced.
Post Reply | |
Tweet
This page was generated in 0,352 seconds.
