Discussion forum
CAD discussion |
Dynamic Block Text Base Point |
Post Reply |
Author | |
rahul7civil
Newbie Joined: 03.Jun.2023 Location: India Using: AutoCAD Web Status: Offline Points: 11 |
Post Options
Thanks(2)
Posted: 05.Jun.2023 at 17:02 |
You can make it by Arctext command Firstly Enter the command then choose the right path check annotation text style etc.
It may help you.
RBanerjee
TECH 011
Groupie Joined: 18.May.2023 Location: Pakistan Using: AutoCAD2023 Status: Offline Points: 34 |
Post Options
Thanks(1)
AutoCAD does not have a unique feature to rotate text automatically.
Stay curious and keep exploring
ME7CADGuy
Newbie Joined: 05.Jun.2023 Location: United Kingdom Using: AutoCAD 2024 Status: Offline Points: 2 |
Post Options
Thanks(0)
Hi CAD Forum,
I'm currently updating my companies block library into dynamic blocks and I need some help with the following. Is there a way for the base point of Mtext/attributed text to automatically adjust when an object is rotated? I want the text to stay 1mm away from the block at all times, I'm currently working on a luminaire block and its default position is horizontal and the text has a base point of top center. When I rotate the block to vertical I want the base point of the text to change to middle right or middle left for example so its still 1mm away from the block. I have sorted the chain actions part so the text still follows the block at the correct orientation, but I cant find a way for the text to auto adjust its base point as the blocks rotates. Is this even possible? Any help or advice will be greatly appreciated. Cheers
Post Reply | |
Tweet
This page was generated in 0,316 seconds.
