Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: External Reference HighlightingPosted: 21.Jul.2010 at 11:19 |
If you work with drawings that have lots of external references in them, chances are you’ve spent a good deal of time trying to figure out which name in the Reference Manager matches a particular reference in the drawing. A new feature in AutoCAD LT 2011 aims to help with that. When you select a reference file in your drawing, the corresponding name in the Reference Manager is highlighted. And when you select a item in the Reference Manager, the corresponding reference is highlighted (but not selected – you have to do that yourself). I admit the highlighting is a little subtle, which is why I’m not even going to try to show it full-size in the blog. Instead, I’ll let you click on the image to see the detail.
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,066 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
