Over 1.116.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
manich44
Groupie
Joined: 24.Jun.2009 Location: United Kingdom Status: Offline Points: 23 |
Topic: How to Create a template?Posted: 25.Feb.2011 at 12:48 |
Hi,
If I want to create a template with title block across the bottom or down the side,do I do it in model or paper space.
Any tips much appreciated....Mark
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2166 |
Posted: 25.Feb.2011 at 12:52 |
Title blocks are usually done in paperspace (in layouts) - they are related to the output plot, not to the drawing contents (model).
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 25.Feb.2011 at 14:12 |
As Vladimir stated, Title Blocks should be in paperspace, but to create a template, I prefer to create my Title Block in Model Space, save the title block as (say) "TitleBlockA1.dwg", then open a new DWG and XREF TitleBlockA1 into one of the Paperspace Tabs.
From there you can save the file with the XREF as a DWT and whenever you create a new DWG, you can start with that DWT. This method gives me full control over modifying the Title Block for past and present DWGs. AND it allows me to insert multiple sheets per DWG - a very handy feature for anyone who uses more than one sheet per DWG. Good Luck!! Edited by HAWDesigner - 25.Feb.2011 at 14:13 |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,102 seconds.
Topic Options
