Discussion forum
CAD discussion |
drawing order standard tool bar |
Post Reply |
Author | |
wildernessld
Newbie Joined: 21.Mar.2008 Status: Offline Points: 3 |
Topic: drawing order standard tool bar Posted: 21.Mar.2008 at 20:57 |
My drawing order tool bar no longer works. I get a command line message :
"Unknown command "UNDER". Press F1 for help."
When I use the tool bar or use the pull down menu.
I can use DRAWORDER at the command line. How do I re-set the tool bar and pul down menu?
Arben.Allaraj
Senior Member Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 22.Mar.2008 at 09:03 |
This means you haven't selected any objects. Change the Pickfirst variable?
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
wildernessld
Posted: 24.Mar.2008 at 16:04 |
Thansk for the reply. Pickfirst variable doesn't change anything. I get the same message whether I pick an object before or after the command. Still searching for a solution.
Arben.Allaraj
Posted: 25.Mar.2008 at 10:03 |
Is working it where you type draworder in command line?
Ing Arben.Allaraj
wildernessld
Posted: 25.Mar.2008 at 17:24 |
It works with the "draworder"command. It does not work with the "draw order" toolbar or pull down.
Arben.Allaraj
Posted: 27.Mar.2008 at 11:09 |
Maybe you can change something in Macro.
Under attach file is the correct macro for draworder compare with it.
Type cui in command line see the picture.uploads/20080327_110853_draworder.rar
Ing Arben.Allaraj
plasticeye
Newbie Joined: 01.Apr.2008 Location: Philippines Status: Offline Points: 1 |
Posted: 01.Apr.2008 at 01:10 |
DR is the shortcut command for draworder
architect
Post Reply | |
Tweet
This page was generated in 0,367 seconds.
