Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Easier Underlay SelectionPosted: 01.Jun.2011 at 10:44 |
I’ve posted before about the frame options for underlays, but in case you’ve forgotten, here they are again: FRAME=0: Frames are not displayed FRAME=1: Frames display and plot FRAME=2: Frames display but do not plot Before now, having the frame visible in the drawing (whether or not it plots) was the only way to select an underlay. But now, the new FRAMESELECTION variable gives you even more options. When FRAMESELECTION is on (set to 1), as it is by default, and FRAME is set to 0, simply passing your cursor over where the border would be (if it were visible) is enough to highlight the underlay and let you select it. If your underlay is a PDF or DWF, with internal geometry, passing your cursor over that also highlights the reference. For example, this circular structure (it’s actually a parking garage—trust me) is a PDF underlay in the drawing. When I move the cursor over it—either where the frame would be or over the geometry itself—the underlay is highlighted. I can then select it and use its contextual ribbon tab, the Properties palette, grips, or regular commands to modify it as necessary. I’ve used the word “underlay” in this post because it’s PDF, DWF, DGN, and image files that always have frames, but clipped DWG files have frames too, and everything in this post applies to them as well.
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,100 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
