Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Stacked Fraction OptionsPosted: 08.Jul.2011 at 11:03 |
I found today’s tip in the July edition of the excellent Michael’s Corner series—I’d never seen this particular option before, and I just love learning new things! Let’s say you’ve got a stacked fraction in AutoCAD LT 2012: But you want to modify it. So you highlight it—an obvious first step. From here, the most obvious second step is to right-click and select “Stack Properties” from the shortcut menu. But, as Michael discovered, if you left-click on the highlighted fraction, a small arrow appears at the bottom. Click on that, and you see “Unstack” and “Stack Properties” right there. From here, you can modify the stack properties or even access the AutoStack feature to control how future fractions are stacked. Double-clicking on the fraction also brings up the Stack Properties dialog, and works in earlier versions of AutoCAD LT too.
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,074 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
