CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 6465
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedData Execution Prevention shuts down installation
 Post Reply Post Reply
Author
matthu View Drop Down
Newbie
Newbie
Using: AutoCad2004, 2005, Inventor2008
Status: Offline
Direct Link To This Post Topic: Data Execution Prevention shuts down installation
    Posted: 02.Oct.2011 at 11:42
Don´t not know what happened, but when I try to install my AutoCad 2005 it doesn´t work, I get a message saying "DEP shuts down the installation to protect your computer". I´ve tried to turn off Data Execution Prevention in settings for this particular program but it doesn´t help, also tried to totally disable DEP but then windows installer shuts down the installation. Must be an update or something from Microsoft, a year ago it worked fine to install? I´m running Windows XP. How do I solve this?
Get following message;
[10/5/2011 17:16:30] === Installation started on MATT-F0A9AD169 by Matt ===
[10/5/2011 17:16:32] [Info] Windows Installer upgrade is not required
[10/5/2011 17:16:32] System Version = 4.5.6001.22159
[10/5/2011 17:16:32] Installation skipped: MSI Runtime 3.0
[10/5/2011 17:16:32] [Info] .NET Framework Runtime upgrade is not required
[10/5/2011 17:16:32] System Version = 4.0.31106.0
[10/5/2011 17:16:32] Installation skipped: .NET Framework Runtime 1.1
[10/5/2011 17:16:32] Installation skipped: .NET Framework Runtime 1.1 SP1
[10/5/2011 17:16:32] [Info] MDAC upgrade is not required
[10/5/2011 17:16:32] System Version = 2.81.1132.0
[10/5/2011 17:16:32] Installation skipped: MDAC 2.7
[10/5/2011 17:16:32] Installation started: Autodesk DWF Viewer
[10/5/2011 17:16:32] Command = "D:\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2
[10/5/2011 17:16:33] [Error: 11] Ett försök att läsa in ett program med ogiltigt format gjordes.
[10/5/2011 17:16:33] Installation failed: Autodesk DWF Viewer
[10/5/2011 17:16:33] [Info] Failure is ignored
[10/5/2011 17:16:33] Installation started: Flash
[10/5/2011 17:16:33] Command = "D:\Bin\AcadFEUI\support\flash\Silent Install Flash Player 7 AX.exe" /q
[10/5/2011 17:16:34] [Error: 1] Incorrect function.
[10/5/2011 17:16:34] Installation failed: Flash
[10/5/2011 17:16:34] [Info] Failure is ignored
[10/5/2011 17:16:34] Installation started: AutoCAD 2005
[10/5/2011 17:16:34] Command = msiexec /i "D:\Bin\AcadFEUI\acad.msi" /L*v C:\DOCUME~1\Matt\LOKALA~1\Temp\AcadInstall.log
[10/5/2011 17:21:05] [Error: -1073741819] (null)[10/5/2011 17:21:05] Installation failed: AutoCAD 2005
[10/5/2011 17:21:05] Installation aborted
[10/5/2011 17:21:11] === Installation ended ===
Edited by matthu - 05.Oct.2011 at 19:03
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,361 seconds.
