Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Two Xref MacrosPosted: 25.Oct.2011 at 10:57 |
Today’s tip comes to you courtesy of Cadalyst Magazine’s “Tips & Tools Weekly” newsletter. Sign up for your own copy or browse the archives here. Admittedly a lot of the tips are LISP-based, but there are plenty that aren’t, or are like this one and can be adapted. CAD Designer Sam Lucido writes: "I often find myself working in a drawing with one or two very large external references attached. Sometimes I just want to unload (not detach) those files to focus on the area I am working in. These macros will do just that— un them and AutoCAD will load or unload all references within the file. This clears up the area and saves on regen time as well! This macro will unload all references: ^C^C-XREF;U;* This macro will load all references: ^C^C-XREF;R;* You can put these on a toolbar, ribbon panel, tool palette, or in a menu—wherever they might make your day easier. Enjoy!
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,109 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Two Xref Macros
Topic Options
