RSS discussions
Discussion Discussion forum
Topic ClosedThe Fundamentals of Friction
 Post Reply Post Reply
Author
BetweenTheLines View Drop Down
RSS robots
RSS robots
Status: Offline
Direct Link To This Post Topic: The Fundamentals of Friction
    Posted: 03.Jan.2012 at 17:48
Rub two sticks together fast enough and you will end up with a fiery demonstration of friction in action. It might seem elementary, but the forces of friction can come with destructive consequences.
Friction in an engine.
Friction causes energy losses that create unwanted heat, deformation, and wear. These unwanted bi-products increase the costs of the products you design while reducing their lifespan.
Friction, however, isn’t altogether destructive. It also helps us move around. Consider how the tires of a sports car grip the road, for instance.
There are a variety of strategies for minimizing and reducing unwanted friction, including:
  • Switching material types
  • Using lubricants
  • Adding wheels or bearings
  • Using magnetics or acoustics to keep objects apart
In short, friction affects every object on the planet in one way or another. With a thorough understanding how friction works, you can create more efficient designs that reduce friction and conserve energy—while maintaining the benefits when they’re needed.
To understand more about reducing friction in your designs, watch this new video on the Sustainability Workshop. http://bit.ly/rR2gtt
Go to the original post...
Between the Lines - Autodesk blog by Shaan Hurley
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,160 seconds.
