Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
BetweenTheLines
RSS robots
Topic: Valentines Day GeometryPosted: 13.Feb.2012 at 18:44 |
You can use my steps below or watch my quick little video showing me creating the heart.Download Heart.MP4 First we need to start with a circle and I used 2 inch radius. The proportions and dimensions are not really important as you can experiment with sizes and proportions for your own heart creation. I then copy the circle from the QUA to QUA so the result is two circles connected at their intersection/tangent. I draw a line from the tangent or Intersection of the two circles. The distance up is not important as we only drew the line up only to create it. We then want to extend the line down roughly 2.5 times the radius of the circle so in my example I extended the line down 5 inches. I could also just draw the line from the intersection down but I like to have an extension beyond the intersection to allow better trimming success in a later step. Now draw a line from the lower tangent of each circle to the end of the line. Trim the bottom portions of the circles. Use the TRIM command in AutoCAD and select all the geometry as cutting edges then hit Enter and select the bottom of each circle. Now you have your heart. After creating you can solid fill with red and then add some text. Do you have some geeky valentine creations to share? Have a Happy Valentines Day! Go to the original post... |
Between the Lines - Autodesk blog by Shaan Hurley
eiji_ouzumi
Newbie
Joined: 14.Feb.2012 Location: Indonesia Using: AutoCAD 2010 Status: Offline Points: 3 |
Posted: 14.Feb.2012 at 08:33 |
im new in this job
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,070 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
