Discussion forum
CAD discussion |
English to French language conversion |
Post Reply |
Author | |
ldconcad
Newbie Joined: 26.Mar.2012 Location: United States Using: Autocad 2005 Status: Offline Points: 1 |
Topic: English to French language conversion Posted: 26.Mar.2012 at 21:47 |
I work for a Mechanical/Electrical Engineering firm in the US. We use AutoCad 2005. Is there any way to convert English to French text using this version? If not, does anyone know where to find French autocad symbols related to mechanical engineering?
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 26.Mar.2012 at 23:03 |
You can try the internal command AMLANGCONV - see http://www.cadforum.cz/cadforum/qaID.asp?tip=5961 (in Czech). Or you can use TRANS utility.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Post Reply | |
Tweet
This page was generated in 0,367 seconds.
