RSS discussions
Discussion Discussion forum
Topic ClosedImporting Inventor Models into AutoCAD
 Post Reply Post Reply
Author
BetweenTheLines View Drop Down
RSS robots
RSS robots
Status: Offline
Direct Link To This Post Topic: Importing Inventor Models into AutoCAD
    Posted: 02.Jul.2012 at 18:17
Guest Post by R.K. McSwain of the ‘CAD Panacea’
One of the new features of AutoCAD 2013 is the ability to import 3D models from a variety of sources including Autodesk Inventor. All versions of Inventor Part (.ipt) and Assembly (.iam) files are supported.
AutoCAD 2013 Ribbon
To get started, click the Insert tab, Import Panel, Import button. Change the files of type to Inventor, browse to find your file, and then click Open. The following information dialogs may appear.
Import Inventor Files into AutoCAD
Import Inventor Files Processing
Click OK on both and the Inventor model will be imported in the background while you continue working. Depending on the size and complexity of the Inventor part or assembly, it may take several minutes. Once the import process is complete, a bubble will appear in the tray.
Import Inventor File Import Complete
Click the link in the bubble and the part will be inserted as a block, on layer 0, into the drawing at coordinate 0,0. This block contains the 3d model which can be used just like any other 3D model in AutoCAD. Use the new tools on the layout tab to create 2D documentation from this model. Kate Morrical has just finished a nice three part article on documenting 3D models in AutoCAD 2013.
The completed part as imported is shown here.
The Completed Imported Inventor File Import Complete in AutoCAD
Thank you R.K. McSwain of the ‘CAD Panacea’.
If you would like to publish a guest article on this blog about Autodesk Products, Tips and Tricks, or Autodesk Technology. To submit a guest post please Email Me for details and consideration.This is a great way to be seen by over 20,000+ people daily for free. The idea is to share tips and articles that benefit Autodesk product and technology users as well as promote you, the expert and your, consulting, books, looking for a job, or promoting your blog.
Go to the original post...
Between the Lines - Autodesk blog by Shaan Hurley
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,242 seconds.
