Please abide by the
rules of this forum.
Author |
Topic Search Topic Options
CheleCity
Newbie
Using: AutoCad2011
Status: Offline
Topic: Double Click does not work? Posted: 25.Mar.2013 at 14:33 |
Also, be sure to check that QAFLAGS is set to 0. It can cause "weirdness" if not
Bassman
Groupie
Using: Autocad 2013
Status: Offline
Posted: 21.Mar.2013 at 16:44 |
heinsite wrote:
Check to see if PICKFIRST=1. Your problem is consistent with it being =0.
Dave. |
Thanx Dave, you helped me too
Autocad 2013
MicahJW
Newbie
Using: ACA2008
Status: Offline
Posted: 13.Feb.2013 at 19:10 |
I was having the same problem today. Also it was not showing in my layers toolbar what lay an object was on if i selected it, it was always showing the current layer. I did check the PICKFIRST, and it was set to 0.
Thanks for the help.
DBARN
Newbie
Using: AUTOCAD 2013, AUTOCAD ARCH 2012
Status: Offline
Posted: 24.Oct.2012 at 22:48 |
ddedit
Man up and Fix it right, Short cuts aren't always short...
heinsite
Senior Member
Using: AutoCAD 2014
Status: Offline
Posted: 19.Oct.2012 at 03:13 |
Dave.
Dave Hein, P.E. Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite
sdhavens
Newbie
Using: AutoCAD 2013
Status: Offline
Posted: 18.Oct.2012 at 23:10 |
Double click to edit text is often very clunky, especially a single line. I usually highlight, right click, and choose edit. Works the first time, every time.
S. Dewayne Havens
Do the best you can with what you have where you are.
brentatterton@h
Groupie
Using: AutoCAD 9, 12, 2000, 2004 all LT versions,
Status: Offline
Posted: 18.Oct.2012 at 16:43 |
I am having a issue with my AutoCAD 2013 version and I am not sure how to fix it let me explain. After I have created a text and I needed to change the wording etc I "use to" just double click on the text and it would open the editor and I could change it. Now that does not work and I also can not double click on a block and open it automatically. I think a setting is change and I can not find it. I also tried opening another drawing (thinking it was the drawing I was in) but it does the same thing so I think its a setting withing Autocad that got change. Can anyone help? Brent
