CZ | EN | DE
Login or
registration
  Visitors: 6056
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedCommand to control if solid patterns appear
 Post Reply Post Reply
Author
ersidhu View Drop Down
Newbie
Newbie
Using: CAD Electrical
Status: Offline
Direct Link To This Post Topic: Command to control if solid patterns appear
    Posted: 20.Dec.2012 at 11:16
Kindly  tell me
Command to control if solid patterns appear for the screen display and for print.
Regards
Thanks & Regards
Ersidhu
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 11:37
Hello ersidhu, from what I understand you will have to explore the command : MVIEW with it's options including (  if applicable to your CAD electrical ) :
SHADEPLOT :
As displayed/Wireframe/Hidden/Visual styles/Rendered.
If you want to print in different visual styles you will have to open a viewport in the paper space and do settings on it otherwise and if you want to print dirrectly from the model space it won't be possible to have other visual styles.
Have you found your CAD PDF documentation or else ???
Edited by philippe JOSEPH - 20.Dec.2012 at 11:41
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 11:50
Are you asking about solid hatching?
Is this another question from your book or exam?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,359 seconds.
