  Visitors: 12206
CAD tip CAD tip # 8351:
Add dynamic text frame to any text.
A - answer With the free DynFrame LISP utility (see Download) you can add a dynamic frame (will follow text changes) to any text - DText or MText.
Download DynFrame, load it with APPLOAD, start the DYNFRAME command and pick any text in your AutoCAD drawing.
DynFrame replaces your text with an framed MLeader of the same size, color, rotation, layer, etc. It does not reflect any special alignments or other special object properties. You can undo its effect if neccessary.
Please note that unlike other "framing" methods (frames added as lines, TCircle, reactors, ordinate dimensions, etc.) this framed text will stay dynamic (frame follows text changes) in any AutoCAD (even without DynFrame loaded) and can be edited by standard double-clicks.
ACAD
2.12.2011    11424×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13805:Projecting/embossing a profile on a curved surface in Fusion 360.
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13749:How to add the SEARCH/REPLACE command into AutoCAD Web?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
