Over 1.096.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 11818:
Question
If you want to increase the size (resolution) of images in the report of the Clash Detective in Autodesk Navisworks, you can perform this change by setting Registry keys for Navisworks.
Run Regedit and in the tree branch HKEY_CURRENT_USER\Software\Autodesk\Navisworks Manage x64\15.0\Clash Detection\Reports change or add numerical (DWORD) keys "Image Height" and "Image Width" (values in pixels). Then repeat the report generation.
The procedure is illustrated in a video:
NW
28.2.2018
9945×
applies to: Navisworks ·
