Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8257:
Question
If you need to transfer your scenes and 3D models from Autodesk 3ds Max to Autodesk Maya, you can use several file formats for this conversion.
Both applications support e.g. the formats: FBX (use the latest version of the FBX plugin), DXF, 3DS, OBJ.
Just export the respective file from 3dsmax and import it in Maya.
maxMaya
11.10.2011    9834×
Share the tip:
applies to: 3ds Max · Maya ·
Tip 14471:What is the Golaem app included in the Autodesk Media and Entertainment Collection?
Tip 14382:Steel and other materials according to DIN or EU standards for Fusion.
Tip 14380:Stereoscopic camera and anaglyphs in Autodesk 3ds Max.
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14349:12 free material texture libraries for PBR rendering.
Back    All CAD Tips
Categ:
