Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1719:
Question
There are several ways to do this.
In the MTEXT editor write the index text as a stacked text - e.g. 2nd/xx hole (if you have AutoStack disabled, select the text to stack - nd/xx, right click and choose 'Stack'). Select the stacked text, right click and choose 'Stack Properties'. Delete nominator or denominator of the stack (e.g. xx). Set the 'Style' to 'Tolerance'. (gives: 2nd hole)
If you are using a font with full Unicode set, you can also use Unicode characters for "2-superscript" - \U+00B2 or "3-superscript" - \U+00B3 or "2-subscript" - \U+2082, to form single-line texts like E=mc2 or H2O. This approach can be used even in plain Text (not MText) entities, dimensions and labels.
If you are using an external Mtext editor (not Internal), you can also use the MText control characters - e.g.:
\A1;TEXT{\H0.5x;\SINDEX;}
(gives: TEXTINDEX)
ACAD2000ACLT2000Map
8.11.2001    177960×   FAQ
Share the tip:
Tip 14080:AutoCAD 2025/2026 is not displaying some fonts correctly.
Tip 11794:Undocumented code in field expression - MText contents without control characters.
Tip 11160:Dynamic display of layer/block/text style/linetype properties.
Tip 10952:All DWG texts in UPPERCASE.
Tip 8640:Text formatting codes in MText objects.
Back    All CAD Tips
Categ:
