Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1880:
Question
Open the block as a separate drawing (WBLOCK it first). Set the INSBASE variable to the desired position. Save (and possible re-insert) the block.
ACADACLT
21.1.2002    36413×
Share the tip:
applies to: AutoCAD · AutoCAD LT ·
Tip 3635:Entities of an inserted block are offset against their original position.
Back    All CAD Tips
Categ:
