CAD tip # 2427:
Tip 13847: | Pringles in AutoCAD - a hyperbolic paraboloid. |
Tip 13788: | Green square - mathematical charade and parametric constraints in AutoCAD. |
Tip 13675: | Two PURGE commands in Autodesk Civil 3D. |
Tip 13604: | Importing points from a Shape file as symbols/blocks mapped to object data. |
Tip 13578: | Change the block attribute type from variable to constant or vice versa. |
MDT can be run only on ADMIN profile, not on the USER.
'Assertion failed in file OPMUI.CPP' error message in 3D Studio VIZ. « | » What prefixes are available for AutoCAD commands?
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools ![]() |
