Over 1.098.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 2671:
Question
The Block option in Divide and Measure commands doesn't support attributes in blocks. As a workaround, you can nest your attributed block in another (new) block a use this block in the Divide/Measure command. After that Explode the block references to edit the individual attributes.
ACADACLT
14.11.2002    10980×
Share the tip:
applies to: AutoCAD · AutoCAD LT ·
Back    All CAD Tips
Categ:
