Over 1.098.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 3492:
Question
If you want to have smaller (more compact) VRML 3D files from your AutoCAD, Architectural or Mechanical Desktop, and Inventor - and if your VRML viewer supports .WRZ files (compressed VRML, e.g. Cortona), you can compress your uncompressed .WRL files from the VRMLout and VRML Translator applications using GZIP (www.gzip.org) - just run e.g. GZIP -9 myfile.wrl and rename the resulting myfile.wrl.gz back to myfile.wrz.
AutoCADADTMDTInventor
22.12.2003    21626×
Share the tip:
applies to: AutoCAD · AutoCAD Architecture · MDT · Inventor ·
Tip 14628:What 3D formats are supported in Autodesk FlexSim?
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 11337:Convert 3D PDF files back to CAD models.
Back    All CAD Tips
Categ:
VRMLout More info
