Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4027:
Question
You can customize (add) your toolbar containing digits or other frequently used characters. To avoid adding CRLF/Enter at the end of the individual buttons, use ^Z or _^H (anything, backspace) - e.g.:
[_Button("8", icon8small.bmp, icon8large.bmp)]8^Z
[_Button("at", iconatsmall.bmp, iconatlarge.bmp)]@^Z
More information about menu customization can be found in the AutoCAD Customization Guide.
ACADACLTADTMap
21.9.2004    11607×
Share the tip:
Tip 9843:How to add Classic workspace (toolbars) to AutoCAD 2015/2016 and higher?
Tip 9602:Do you know how to customize your QAT panel?
Tip 8493:Missing context menus and toolbars in Inventor 2012.
Tip 8330:Rendering stereoscopic images in 3ds Max (anaglyphs).
Tip 7884:Inventor trick - new empty drawing sheet.
Back    All CAD Tips
Categ:
