Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4477:
Question
You can use the same command as for 2D filleting to add radius e.g. to box edges - FILLET.
ACAD
18.6.2005    16137×
Share the tip:
applies to: AutoCAD ·
Tip 14232:How to find out the fillet radius of a 3D solid?
Tip 14192:MLfillet - how to fillet multilines in AutoCAD?
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12782:How to insert a character in Kanji or Pinyin into Fusion 360?
Tip 12248:How to remove fillet or chamfer from a 3D solid?
Back    All CAD Tips
Categ:
