Over 1.098.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4718:
Question
It is not easy to draw circular text (text along an arc) in AutoCAD LT as there is not the ARCTEXT Express Tool.
As a (limited) workaround you can insert a WordArt object from MS Word. In AutoCAD LT, use Insert > OLE Object and select "Microsoft Word Picture" or "Microsoft Word Document". In MS Word use the WordArt tool (toolbar) to write your arc text. Save and exit Word.
ACLT
4.11.2005    34133×
Share the tip:
applies to: AutoCAD LT ·
Tip 14615:How to create negative dimensions in AutoCAD?
Tip 14560:JobTime for Autodesk Fusion - tracking time spent on a job.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14477:PurgeAll - automation of DWG file cleaning
Tip 14349:12 free material texture libraries for PBR rendering.
Back    All CAD Tips
Categ:
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
