Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5987:
Question
To find backward references - i.e. list of assemblies referencing a given Inventor part - you can use the "Design Assistant" utility.
Launch Design Assistant from the Inventor application group. Using the Open command open the tested IPT file of your part. Run the function Tools > Find > Where used. In the dialog, specify paths and file types which will be searched. You may want to check the subfolders option. Run the search. All IAM assemblies containing the part will be listed.
Inventor
17.2.2008    5543×
Share the tip:
applies to: Inventor ·
Tip 14339:Time tracker for Autodesk Inventor - how much time have I spend on a design?
Tip 14117:Recoloring of Inventor assembly parts - random, by material, by mass or other property (T4I)
Tip 13997:4 methods of 3D orbit in Inventor, with specified pivot.
Tip 13920:Saving your Inventor model in the presentation color scheme, thumbnails with a white background (iLogic).
Tip 13824:How to export OBJ including materials, textures from Inventor?
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
