Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 14202:
Question
When I run the PUBLISH command, I repeatedly get many "Duplicate Sheet Name" warnings. How to get rid of them?
These warnings result from opening multiple copies of the same DWG file (e.g. different versions of a drawing), or drawing files of the same name, or layouts of the same name, in combination with the "Automatically load all open drawings" option.
In addition, if you have the "Prefix sheet title with file name" option turned off when adding sheets, the situation gets worse because more sheets with the same name "Model" or "Layout1" will be created.
So in this situation, duplicate named sheets really do occur and AutoCAD warns against this condition. However, the amount of dialogs that need to be individually confirmed (depending on the number of layouts and open copies) can be quite annoying. So deselect the automatic loading option and use it only judiciously.
tip by: Johny
ACADACLTADTACADMPlantMapCivil3D
14.8.2024    1803×
Share the tip:
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 13778:How to publish several DWG drawings into one multi-page PDF?
Tip 11821:How to publish PDF sheets (pages) under the plain layout name?
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 9147:Batch publishing to PDF uses different margins than single prints.
Back    All CAD Tips
Categ:
