Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7806:
Question
How to export a drawing from DWG to PDF so that the drawing texts behave in the PDF like texts - ie. they can be selected, searched, indexed?
Just write the text using one of the TrueType fonts/styles (in the standard width). Then the classic commands EXPORTPDF, PUBLISH and PLOT will publish - using the internal AutoCAD print PDF-driver (DWG To PDF.pc3) standard "text-based" PDF files. On the contrary, texts based on SHX fonts will be exported as vectors.
See a sample PDF output from DWG
ACAD2011ACAD2010ACLTADTCivilACADM
22.2.2011
28138×
applies to: AutoCAD 2011 · AutoCAD 2010 · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
