Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11751:
Question
With the freeware utility toMulti you can convert selected polylines (LWpolyline) to multi-lines (group of polylines) according to a predefined definition table. The resulting line supports (unlike MLine) also line widths, arc segments, and start and end-blocks on the polyline - so it can handle more complex combinations. Alas, it is not associative and editable as an object - the conversion creates a group of individual lines.
The LISP application toMulti can be downloaded from DL Download. Unpack the ZIP file (containing the .VLX and .TAB file) to an AutoCAD support path, load the application with APPLOAD and run it by typing the TOMULTI command.
The command prompts to select the polylines and the name of one of the definitions prescribed in the .TAB file (must be accessible in search path). Then it converts selected polylines to multi-lines.
The text file ToMulti.tab can be edited in Notepadu - its format contains the definition names (prefixed with an asterisk) and the respective segments with definitions of the offset (from the original line), color (code or name), line width, linetype and layer (since v1.2). Except for the offset, all parameters are optional. It can also contain names of the start and end-block on the polyline (prefixed with "#") - they must exist in the drawing. Since version you can also prescribe start and end caps (e.g. for hatching).
Since version 1.3 you can use layer names with spaces (must be enclosed in double quotes) and RGB color codes (a triplet in parentheses).
; *DefinitionName1
; offset[,color[,width[,linetype[,layer]]]]
; [#startBlockName[,#endBlockName]]
; *DefinitionName2
; S|E|B[,color[,width[,linetype[,layer]]]]
; multi-word layer names as "My Layer", RGB colors as (R,G,B) values
*Fuskic
0.25,30,0.25
-0.25,30,0.25
0,51,0.25
0,1,0.08,Dashed
#circle,#arrow
*SimpleDup
0.25
-0.25
*CappedDup
0.25,(255,0,0),0,Continuous,Offset1
-0.25,_ByLayer,0,Continuous,"Offset 2"
B,2
The variable DELOBJ controls deletion of the original (control) polyline.
When you set the LISP variable (setq _toMultiGroup T), the resulting lines will be grouped into an anonymous group (selected as one object).
ACADADTCivilACADMABS
10.1.2018    28521×
Share the tip:
Tip 14489:Multiline header of a parts list in an Inventor drawing.
Tip 14484:Minimum, maximum, average, sum and delta values from selected drawing texts.
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Tip 14395:CheckAngles - checking the allowed line angles in the DWG drawing (e.g. only ortho)
Tip 14230:How to transfer layer properties from another DWG drawing?
Back    All CAD Tips
Categ:
