  Visitors: 8171
CAD tip CAD tip # 7334:
Using FSMODE to control selection of touching objects.
A - answer If you need to quickly select touching objects, you can use one of the useful Express Tools - FS (FastSel).
Depending on the setting of its work mode (FSMODE, "chain mode"), when you select a single object, all objects directly touching the selected object will be also selected (FSMODE=OFF), or even also the objects touching the touched objects will be selected (FSMODE=ON, chain selection).
FS (FSMODE=OFF)
Select with FS (FSMODE=OFF)
FS (FSMODE=ON)
Select with FS (FSMODE=ON)
You can use the FS command either as a standalone command (grip edit selection), or transparently ('FS) inside any AutoCAD prompt "Select objects:". So you can effectively select objects in complicated situations.
ACADADTCivil
28.4.2010    11375×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD Architecture · Civil 3D ·
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 11295:Iterative Move, Scale and Rotate - till boundary touch.
Tip 10926:Self-intersecting polylines and polylines with duplicate vertices.
Tip 8121:Do you know the AutoCAD command "space invaders"?
Tip 7648:Area not displayed for some boundaries or hatches.
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
