RSS discussions
Discussion Discussion forum
Topic Closedhelp!!!!1
 Post Reply Post Reply Page  12>
Author
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Topic: help!!!!1
    Posted: 30.Jul.2010 at 00:47
Back to Top
Cuty View Drop Down
Newbie
Newbie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 29.Jul.2010 at 21:16
I want to thank you for helping me in my last problem.
Now I have one question... I have installed AutoCAD R14 because I have one thing to try ...
But the problem is that when I start AutoCAD a error is shown ... It writes "MEM_BAD_POINTER" Do you know enything about that???????
Cuty
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 20:08
Originally posted by Cuty Cuty wrote:
There is stil a problem, i have copied ti into the command bar, presed Enter and tiped "dx". This text shows:
Pick first point: Pick second point:    (I pick points)
And after that the program still doesnt give me the horizontal distance (it works like the normal dist command).
Am I doing something wrong, I do not understand..???
 It is ok in 2009.
 Check this url below maybe it help you.
Edited by Arben.Allaraj - 15.Jul.2010 at 20:13
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 18:02
The code uses the regular "dist" command, but uses just the x-y values of the points you picked. So check the output and see if that is happening.
Back to Top
Cuty View Drop Down
Newbie
Newbie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 14:04
Cuty
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 13.Jul.2010 at 22:28
Sorry, apparently code was not as simple as I thought, I had wrong command (distance vs dist) and wrong input order, still didn't work right. So took a different approach, try this:
(defun c:dx ()
   (setq Pt1 (getpoint "\nPick first point: "))
   (setq Pt2 (getpoint Pt1 "Pick second point: "))
   (setq Pt1x (list (car Pt1) (cadr Pt1)))
   (setq Pt2x (list (car Pt2) (cadr Pt2)))
   (command "_dist" Pt1x pt2x)
   (princ)
Back to Top
Cuty View Drop Down
Newbie
Newbie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 13.Jul.2010 at 10:35
Yes, I did as you sead, I copied it and then tiped "dx"
after that that in the command line appered this text:
Command: .xy Unknown command "XY". Press F1 for help.
Command: 0 Unknown command "0". Press F1 for help.
Cuty
Back to Top
Zupmicher View Drop Down
Newbie
Newbie
Using: Autocad 2011
Status: Offline
Direct Link To This Post Posted: 12.Jul.2010 at 19:48
only to offset and help commands
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 12.Jul.2010 at 09:08
Did you type "dx" after copying (loading) it?
See i said explaining running the lisp was more involved; it was 3 steps: copy; paste, type "dx" :)
Back to Top
Cuty View Drop Down
Newbie
Newbie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 12.Jul.2010 at 08:27
I do not understand.. the lisp code you gave mi.. how does it work.. I copyed it into the comand line and it doesnt worh????
Cuty
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,067 seconds.
