RSS discussions
Discussion Discussion forum
Topic Closed2011 loft problem
 Post Reply Post Reply Page  12>
Author
Rikky View Drop Down
Groupie
Groupie
Using: 2004 2006 2007 2009
Status: Offline
Direct Link To This Post Topic: 2011 loft problem
    Posted: 07.Jan.2011 at 16:38
Hello,
At first.. My english is not verry good...
I work with AutoCAD 2011 and works a lot with 3D.
But now with 2011 when I try to loft, he makes a surface.
Now you can choose in loft between solid and a surface... And even when I choose for solid he wil make a surface...
Does somebody know what I do wrong or what I have to do to make a solid...
Thanks in advance.
Greetz,
Rikky
Autodesk Certified Engineer: ACE 3D Designer
AutoCAD 2011 professional
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 07.Jan.2011 at 16:51
Hi Rikky. I will try to explain this with your lack of English Skills in mind.
You know that LOFT requires minimum 2 cross sections, correct?
And you know what it means to have "Open" and "Closed" cross sections, correct?
IF any one cross section is Open, the resulting LOFT will be a Surface.
IF ALL cross sections are Closed, the resulting LOFT will be a Solid.
Does this help?
Edited by HAWDesigner - 07.Jan.2011 at 17:12
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 07.Jan.2011 at 17:26
Also Rikky, please see this: http://forums.autodesk.com/t5/AutoCAD-2011/Problem-with-lofting-in-2011/m-p/2733093#M4477
Note the attachment at the bottom of the post.
R. Williams
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 10.Jan.2011 at 13:15
The cross section is close... And at the last isnt my problem becease when I instal AutoCAD 2011 I could work LOFT and he make a perfecly soid...
But now a couple of weeks later he cant make a solid...
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 10.Jan.2011 at 15:47
Ok, did you view the link I provided above?
Did that help?
R. Williams
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 11.Jan.2011 at 08:08
I viewed the link yes... But what I don't understand is that I have to make first a surface and than a solid...
Why is that I never did that before sow I am sure that some of the settings are wrong...
And I try the thing what the link said but I not really understand it...
Everybody Thank you verry mutch for helping hopaly it leads to a solution...
Edited by Rikky - 11.Jan.2011 at 08:08
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 11.Jan.2011 at 15:44
I understand your confusion. I was confused at first too. The poster "wengle" is incorrect. Follow the instruction of JDMather...and look at the image he posted.
Good Luck!!
R. Williams
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 12.Jan.2011 at 14:44
I know about the new function but even if I make sure he is on solid, he wil make surface...
my steps,
View SW isometric.
make a circle by pressing c enter.
Than I make a region from this circle (it isnt nessesary but now I am sure he is closed)
I copy the circle over the Z axle
press loft mode is on solid...
And still he make a surface
(it doesnt make anny sence what for object it is...)
_______________________________________
Command: c CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan
radius)]:
Specify radius of circle or [Diameter] <0.3967>: 1
Command: region
Select objects: Specify opposite corner: 1 found
Select objects:
1 loop extracted.
1 Region created.
Command: Specify opposite corner:
Command: co COPY 1 found
Current settings:  Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>: Specify second point
or <use first point as displacement>: 1.5
Specify second point or [Exit/Undo] <Exit>: *Cancel*
Command: loft
Current wire frame density:  ISOLINES=4, Closed profiles creation mode = Solid
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1
found
found, 2 total
 2 cross sections selected
Enter an option [Guides/Path/Cross sections only/Settings/COntinuity/Bulge
magnitude] <Cross sections only>:
Command:
_______________________________________________
so you can see...
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 12.Jan.2011 at 16:20
I see. Ok, I followed your steps and produced a "3DSOLID". I also tried it with a Circle and with a Region and both were the same. That leads me to believe that it may be a lofting setting in your system that could be set incorrectly.
Here are my lofting System Variable settings:
LOFTANG1 = 90d
LOFTANG2 = 90d
LOFTMAG1 = 0.0000
LOFTMAG2 = 0.0000
LOFTNORMALS = 1
LOFTPARAM = 7
Maybe you can try setting yours to the same and trying again?
Good Luck!!
R. Williams
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jan.2011 at 15:40
I acutaly checked them before I asked this question and they are the same haha.
So it is a verry strange problem...
Do you have more options?
Again thank you terry verry mutch for helping! I appreciate it verry mutch!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,084 seconds.
