RSS discussions
Discussion Discussion forum
Topic Closedeasy shortcut question
 Post Reply Post Reply
Author
germanbarry View Drop Down
Groupie
Groupie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Topic: easy shortcut question
    Posted: 07.Jun.2011 at 09:39
hi all
I am often switching between world coords and vertical coords. at the moment to do this i type in UCS > W and UCS > V, which requires a total of 6 keystrokes (including enter key) to make the switch.
if i want to make a shortcut for these commands to simply be UV and UW (halving my keystrokes), does that require a lisp, since it's not a stand-alone command name change, rather the command AND its subsequent sub-command?
if not a lisp, how do I do it?
sorry if this is a n00b question.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Jun.2011 at 12:04
You could probably create two different macros and assign them to individual buttons placed on a custom Toolbar.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 07.Jun.2011 at 12:35
no I couldn't.... but I'm guessing YOU could!!? ;-)
not really sure how to do this, but could I somehow make an additional entry into the acaddoc.lsp file to get this shortcut happening?
I wouldn't know where to put it, or what exactly the code should be, but if that's an (easier?) option, then advice on it would be also appreciated!
is the acaddoc.lsp file called exactly that if I'm using 2011 version? I can only find this lisp file:
C:\Program Files\Autodesk\ACA2011ENU\Support\acad2011doc
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Jun.2011 at 18:09
A macro and a lisp are not the same thing.
Which do you want to have/use?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 08.Jun.2011 at 07:55
don't really care if they have the same effect... whichever is easier to implement I suppose?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Jun.2011 at 12:39
Since you are using a full version of AutoCAD why not use the Action Recorder found on the Manage tab to record two simple macros?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 08.Jun.2011 at 14:03
that's the answer I was after!
haven't used macros with this CAD version yet, but thanks for explaining how. piece of cake for a simple function like this.
cheers
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,076 seconds.
