Over 1.127.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
Page 12> |
| Author | |
jbaylie
Newbie
Joined: 29.Mar.2013 Location: United States Using: AutoCAD2013 Status: Offline Points: 3 |
Topic: Legal Description QuestionPosted: 29.Mar.2013 at 01:11 |
I am trying to draw a legal description in autoCAD 2013, i have formatted my drawing units to surveryos units and i was going along just fine until i got to a curve.
How do i continue my drawing and add the curve? this is what I am given: "Thence along a curve to the right having a central angle of 19'21'33. A radius of 694.26 feet. An arc length of of 234.58 feet and a chord that bears north 35d29'19"" I dont know what to do with that information so that it will draw it the correct arc.....PLEASE HELP
Edited by jbaylie - 29.Mar.2013 at 01:14 |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 29.Mar.2013 at 11:09 |
That's a typical horizontal curve which anyone familiar with basic math should know how to construct. You have all the information you need (angle and radius) plus some extra (arc length and chord). Try an Internet search for "horizontal curve" and you'll see how one is constructed. Remember that your radius has to be perpendicular to the property lines on either side of the curve.
<<AutoCAD 2015>> |
jbaylie
Newbie
Posted: 29.Mar.2013 at 14:19 |
did not say it was hard, i sadi i was stuck. I looked it up on the internet and got here, i figured this was the place but i guess not. |
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1525 |
Posted: 29.Mar.2013 at 14:35 |
uploads/175428/CURVE01_A.dwg
Hello John, please tell me ( us ) if it's ok because it's also not too much easy for me ( including the barrier of the language and units of course ).
John Connor
Senior Member
Posted: 29.Mar.2013 at 21:48 |
Draw a circle with the given radius.
Draw a line from the center of the circle to the easterly quadrant of the circle. Draw a second line using the direct distance entry method (at the command line) as follows... @694.26'<19d21'33" Trim the circle leaving the arc between the two lines you drew intact. That's your curve. Now go do it for your property map. |
<<AutoCAD 2015>> |
CarlB
Senior Member
Joined: 16.Oct.2009 Location: United States Status: Offline Points: 321 |
Posted: 30.Mar.2013 at 01:21 |
The last line you drew prior to the curve should be tangent to the curve (or description would have said "non-tangent"). Offset this line to the right, a distance equal to the curve radius. The end of the offset line will be the center of the curve. Draw a line between those endpoints, rotate that line by the central angle, this will set the end of the curve. Draw a circle and trim to get desired curve.
philippe JOSEPH
Senior Member
Posted: 02.Apr.2013 at 10:04 |
Ok John and CarlB for the central angle of 19d21'33, radius of 694.26 giving an arc of 234.58 feet but where is the chord bearing north 35d29'19" ?
Please take a look at my uploaded drawing CURVE01_A.dwg for me ( us ) understanding better ( or understanding at all ).
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 02.Apr.2013 at 16:00 |
uploads/353260/ArcLength.lsp
Try out the attached ArcLength.lsp with its ARCL command [a new .LSP version I just made of what I've had as a screen menu item for many years] -- a way to draw an Arc including specifying the LENGTH ALONG THE CURVE [an aspect you can't use in AutoCAD's ways of drawing Arcs, unless that's been changed in a newer version than mine]. It was designed for property-description Arcs like your example. It asks for the start point [defaulting to the last point, usually of a preceding Line but including getting it right for a preceding Arc if that was drawn with this command], starting direction [defaulting to tangent continuation as is so often the case in property boundaries], radius, length along the Arc, and whether it curves left or right.
At this point that's the only variety of Arc it draws, but I may work on a version, or an option in this, to specify by length and direction of chord.
CarlB
Senior Member
Posted: 03.Apr.2013 at 03:08 |
The chord is the straight line from beginning to end of the curve. You have it in your drawing. if you change units to "survey" and list the line, it reads:
LINE Layer: "0" Space: Model space Handle = 12e86 from point, X=68'-6.90566369" Y=63'-1.85544090" Z=0'-0.00000000" to point, X=57'-3.37070543" Y=47'-3.76252329" Z=0'-0.00000000" Length =19'-5.46314963", Angle in XY Plane = S 35d29'19.0000" W A line with bearing SxxxxW is same as one of NxxxxE (just reversed endpoints). The original poster neglected to specify a "W" or "E" at the end of the chord bearing. |
philippe JOSEPH
Senior Member
Posted: 03.Apr.2013 at 07:45 |
Hello CarlB, thanks again for your explanations ( I know what is a chord, an arc, an arrow ).
I just wanted to know if the drawing was in the good direction towards the north with the OP informations :
A curve to the RIGHT ............a chord that bears north 35d29'19".
I have AutoCAD Mechanical 2012 and when I use the command UNITS I get the palette that you can see in my drawing ( unité de dessin ) and I don't have "survey" but :
Architecture, Décimal, Fractionnaire, Ingénierie ( that I choose ) and Scientifique ( It's written in my AutoCAD french release but I'm sure that you can understand it very well ).
Can you update my drawing with the right units setings, rotate the chord to the right angle towards the north and upload it again ?
By the way we don't have any news from jbaylie, have you done your drawing allright ?
Post Reply
Page 12> |
Tweet
This page was generated in 0,113 seconds.
Topic Options
