Discussion forum
Post Reply
| Author | |
harrisrwe
Newbie
Joined: 11.Jul.2013 Location: United States Using: Catia Status: Offline Points: 3 |
Topic: STL2DWG Converter ProblemsPosted: 11.Jul.2013 at 17:06 |
Hi everyone,
I downloaded an STL file of an OUYA case (the new game system) and I'm trying to convert it so that I can modify it, but every time I try to use the STL2DWG converter available on this site, it gives me an error. The file is 17MB so it's within the 20MB limit, I downloaded GLC Player to test the file, and it works fine, so there's no corruption. Does anybody know a fix? Or of another STL to DWG/DXF/SCR converter? Thanks! |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 11.Jul.2013 at 17:50 |
You can import a STL file into Inventor Fusion. Assuming all goes well there might be a way to generate a DWG file but since I've never had a need to do it I cannot say for sure it can be done.
<<AutoCAD 2015>> |
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 11.Jul.2013 at 19:56 |
Can you please send me the STL file (a link to download it)? I will check the STL2DWG process.
In any case, Inventor Fusion is a way to go - you can re-export the imported file to SAT, STEP or IGES. There are also other conversion methods from STL to DWG - see:
Vladimir Michl (moderator)
harrisrwe
Newbie
Posted: 11.Jul.2013 at 22:04 |
Sure! The file is available here:
http://www.thingiverse.com/download:162285 If that doesn't work, go here: http://www.thingiverse.com/thing:66411 Click "Download this thing" then right-click save as "Case.stl" Thanks for the support! |
Post Reply
Tweet
This page was generated in 0,191 seconds.
Topic Options
