RSS discussions
Discussion Discussion forum
Topic ClosedLabel Macro Help
 Post Reply Post Reply
Author
kaleden View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Label Macro Help
    Posted: 30.Sep.2008 at 00:41
So I'm working with AutoCAD LT and wanted to create a quick macro to label points on my drawing with the XY coordinates.
My macro SHOULD look like the following:
^C^C_id;\_setenv;mypoint;$M=$(getvar,lastpoint);_qleader;@;\;4;($M=$(rtos,$(index,0,$(getenv,mypoint)),2,1),$M=$(rtos,$(index,1,$(getenv,mypoint)),2,1));;
The idea is as follows:
  1. The user to specifies a point (_id;\)
  2. A variable is set with that point (_setenv;mypoint;$M=$(getvar,lastpoint);
  3. A leader is created with the first point at the location specified in (1) (_qleader;@;)
  4. The user specifies the final point and the mypoint variable is spit out in the mtext box. (\;4;.... the remainder of the code).
The problem I'm having is that "mypoint," though set correctly, isn't being recalled correctly. getenv seems to recall the previous state of "mypoint" only when using $M=$(getvar,lastpoint). If, however, I prompted the user to specify the variable value, getenv would properly pull it out and label the leader.
Perplexing.
My current workaround involves splitting the macro into two parts:
^C^C_qleader;@;\;4;$M=$(rtos,$(index,0,$(getenv,mypoint)),2,1),$M=$(rtos,$(index,1,$(getenv,mypoint)),2,1));;
This works, but I have to hit two shortcuts instead of one.
Can anyone help me bring this macro into one? Am I the only one having issues with this macro?
Thanks.
Back to Top
saverio View Drop Down
Newbie
Newbie
Using: AutoCAD All versions
Status: Offline
Direct Link To This Post Posted: 21.Oct.2008 at 02:18
All diesel macro are avaluated before executed.
So your getenv is evaluated BEFORE you clic. No way to solve this
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 21.Oct.2008 at 14:10
In fact there are ways to solve this - e.g. the LT Extension add-on uses a lot of such Diesel macros.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Sedlacek View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 21.Oct.2008 at 16:09
Use quotes.
^C^C_id;\_setenv;mypoint;$M=$(getvar,lastpoint);_qleader;@;\;4;"($M=$(rtos,$(index,0,$(getenv,mypoint)),2,1),$M=$(rtos,$(index,1,$(getenv,mypoint)),2,1))";;
or
^C^C_id;\_setenv;mypoint;$M=$(getvar,lastpoint);_qleader;@;\;4;"$M=$(rtos,$(index,0,$(getenv,mypoint)),2,1),$M=$(rtos,$(index,1,$(getenv,mypoint)),2,1)";;^Z
Edited by Sedlacek - 21.Oct.2008 at 16:35
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,137 seconds.
