RSS discussions
Discussion Discussion forum
Problem starting Fusion
 Post Reply Post Reply
Author
HubertJ View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote HubertJ Quote  Post ReplyReply Direct Link To This Post Topic: Problem starting Fusion
    Posted: 12.Mar.2026 at 06:41
I have a problem starting Autodesk Fusion. Suddenly, when I double click the Fusion icon, it reports the error that Qt6Widgets.dll is not found:
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vladimir Michl Quote  Post ReplyReply Direct Link To This Post Posted: 12.Mar.2026 at 08:28
Try the Repair option in the Fusion Service Utility or reinstall Fusion. You DLLs may got corrupted or blocked.
See
https://www.cadforum.cz/en/fusion-code-execution-cannot-proceed-because-dll-not-found-tip14941
Vladimir Michl (moderator)
Back to Top
julecave View Drop Down
Groupie
Groupie
Using: audocad 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote julecave Quote  Post ReplyReply Direct Link To This Post Posted: 24.Mar.2026 at 20:17
thanksa a lto !!!
Back to Top
Newbie
Newbie
Using: AutoCAD
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote HubertJ Quote  Post ReplyReply Direct Link To This Post Posted: 12.Apr.2026 at 11:56
This fix has helped, thanks!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,176 seconds.
