Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
Page <123> |
| Author | |
lorenz
Newbie
Joined: 27.Feb.2009 Location: Italy Status: Offline Points: 9 |
Posted: 27.Feb.2009 at 16:02 |
Thank you very much for your reply. I downloaded this new file from the download section but i cannot understand how to use this function to measure and display the perimeter. I digited "farea" in the Autocad command section but I'm only able to measure area.......
Can you help me again? Thanks, Lorenzo |
lorenz
Newbie
Posted: 27.Feb.2009 at 16:03 |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 27.Feb.2009 at 16:50 |
Please type-in the FLENGTH command, pick your polyline and a sample (template) text. You can also specify the label text by start point, height and orientation. Please note that FAREA and FLENGHT only simplify the standard FIELD command in AutoCAD. |
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
lorenz
Newbie
Posted: 27.Feb.2009 at 16:59 |
Hi Vladimir,
thank you again but when I type "flength" command I see "unknown command". Please tell me whether my procedure to load "farea" is correct: - I downloaded from the "download" section, - go to "Tools" --> AutoLisp --> Load Application - Select "farea.vlx" and load Then typing "farea" it works great, but typing "flength" I see "Unknown command" in autocad command prompt....... Have I made some mistake? Thanks a lot! Lorenzo |
lorenz
Newbie
Posted: 03.Mar.2009 at 16:24 |
Please, someone can tell me how to use the "flenght" command of "farea" routine? It's really important for what I have to do...
Thank you ..... Lorenzo |
Vladimir Michl
Moderator Group
Posted: 03.Mar.2009 at 16:32 |
I am sorry - a typo: should be "FLENGTH" (the prompts are the same as in FAREA)
lorenz
Newbie
Posted: 03.Mar.2009 at 16:40 |
Hi Vladimir,
I don't want to bother you... really, but I tried "FLENGHT", "FLENGTH" etc..... and I see "Unknown command" while the "farea" command works perfectly.... Do you know why? Regards, Lorenzo |
Vladimir Michl
Moderator Group
Posted: 03.Mar.2009 at 16:46 |
Are you sure you are using the latest (the updated) version of FArea.vlx from February?
It should sign on as:
FAREA+FLENGTH commands loaded. (C)2009, XANADU - www.xanadu.cz
______ CAD, PLM, GIS/FM custom application development _______ |
lorenz
Newbie
Posted: 03.Mar.2009 at 16:54 |
Hi Vladimir,
- I downloaded farea.vlx (V 1.2) from the "download" section, - go to "Tools" --> AutoLisp --> Load Application - Select "farea.vlx" and load Then typing "farea" it works great, but typing "flength" I see "Unknown command" in autocad command prompt....... Have I made some mistake? Lorenzo |
lorenz
Newbie
Posted: 03.Mar.2009 at 16:58 |
I see only:
FAREA command loaded. (C)2009, XANADU - www.xanadu.cz
______ CAD, PLM, GIS/FM custom application development _______ Do you have the right version to send me by email?? Thanks, Lorenzo |
Post Reply
Page <123> |
Tweet
This page was generated in 0,100 seconds.
Measuring using 'farea'
Topic Options
