RSS discussions
Discussion Discussion forum
Topic ClosedMeasuring using 'farea'
 Post Reply Post Reply Page  <123>
Author
lorenz View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 27.Feb.2009 at 16:02
Thank you very much for your reply. I downloaded this new file from the download section but i cannot understand how to use this function to measure and display the perimeter. I digited "farea" in the Autocad command section but I'm only able to measure area.......
Can you help me again?
Thanks,
Lorenzo
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 27.Feb.2009 at 16:03
Thanks,
Lorenzo
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 27.Feb.2009 at 16:50
Please type-in the FLENGTH command, pick your polyline and a sample (template) text. You can also specify the label text by start point, height and orientation.
Please note that FAREA and FLENGHT only simplify the standard FIELD command in AutoCAD.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 27.Feb.2009 at 16:59
Hi Vladimir,
thank you again but when I type "flength" command I see "unknown command". Please tell me whether my procedure to load "farea" is correct:
- I downloaded from the "download" section,
- go to "Tools" --> AutoLisp --> Load Application
- Select "farea.vlx" and load
Then typing "farea" it works great, but typing "flength" I see "Unknown command" in autocad command prompt.......
Have I made some mistake?
Thanks a lot!
Lorenzo
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:24
Please, someone can tell me how to use the "flenght" command of "farea" routine? It's really important for what I have to do...
Thank you .....
Lorenzo
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:32
I am sorry - a typo: should be "FLENGTH" (the prompts are the same as in FAREA)
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:40
Hi Vladimir,
I don't want to bother you... really, but I tried "FLENGHT", "FLENGTH" etc..... and I see "Unknown command" while the "farea" command works perfectly....
Do you know why?
Regards,
Lorenzo
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:46
Are you sure you are using the latest (the updated) version of FArea.vlx from February?
It should sign on as:
FAREA+FLENGTH commands loaded.  (C)2009, XANADU - www.xanadu.cz
______ CAD, PLM, GIS/FM custom application development _______
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:54
Hi Vladimir,
- I downloaded farea.vlx (V 1.2) from the "download" section,
Lorenzo
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 16:58
I see only:
FAREA command loaded.  (C)2009, XANADU - www.xanadu.cz
Do you have the right version to send me by email??
Thanks,
Lorenzo
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,211 seconds.
