RSS discussions
Discussion Discussion forum
Topic ClosedBlock - Design Center
 Post Reply Post Reply
Author
mrbill542 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Block - Design Center
    Posted: 14.Apr.2009 at 18:52
I have blocks that I created in design center that were moved to a new server. How can I remap the support path to the new server removing the old one? It currently searches for the old one which is taking up to much time.
Back to Top
msplcdykee69 View Drop Down
Senior Member
Senior Member
Using: Civil 3D, Map, Inventor, Mechanical, & Electrical
Status: Offline
Direct Link To This Post Posted: 15.Apr.2009 at 14:01
You want to change the default startup directory for AutoCAD® DesignCenter™.
Solution
Use the ADCNAVIGATE command to change the default startup directory for AutoCAD DesignCenter.
To set the default startup directory for DesignCenter:
  1. Type adcnavigate on the command line and press ENTER.
  2. Enter the default startup location.
  3. Press ENTER.
Following are the valid directories for AutoCAD DesignCenter:
  • Drive letter and path: for example, c:\program files\acad2000\sample
  • Drive letter, path and file name: for example, c:\program files\acad2000\sample\opera.dwg
  • UNC Network Path: for example, \\server\acad2000\sample
Note: According to AutoCAD or AutoCAD LT Help, ADCNAVIGATE supports remote domains or workgroups if you have the target domain or workgroup mapped to a drive letter.
I hope this helps.
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Apr.2009 at 01:02
Thank you. Does that change apply to the tool palettes as well?
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 16.Apr.2009 at 05:09
For that, I am not sure.  I will see what I can find out and get back to you, unless someone else on here beats me to the answer.
Shawn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,174 seconds.
