RSS discussions
Discussion Discussion forum
Topic ClosedPlotting Issues
 Post Reply Post Reply Page  12>
Author
ISElation View Drop Down
Groupie
Groupie
Using: AutoCAD Map 2011
Status: Offline
Direct Link To This Post Topic: Plotting Issues
    Posted: 14.Mar.2011 at 16:54
When trying to plot out my drawing it is getting cut off on the right edge by about 3 inches of what i window when i use ansi C landscape paper. I have tried changing my drawing limits. I am using scale to fit. Can someone tell me whats the proble here.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 17:02
It seems unusual that a plot done using the "Window" and "To Fit" options would get cut off at all.
Are you plotting from model space or a paper space layout?
Can you post the drawing?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 17:21
It cuts it off in both model and paperspace layout.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 17:26
Is this a 2D or 3D drawing?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 17:28
its a 2d drawing. I don't have rights to post the drawing.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 17:38
Then post a screen shot of your Plot dialog window so we can see ALL your settings.
Another option instead of posting the entire drawing would be to erase most objects, any identifying text, and put a rectangle around the area you were trying to print using the Window option and put a couple of diagonal lines through it.
Edited by John Connor - 14.Mar.2011 at 17:41
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 18:47
I powered down the plotter and started it up again and it seams to be plotting fine now.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2011 at 18:59
Alls well that ends well.  Thanks for letting us know.
<<AutoCAD 2015>>
Back to Top
otil View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Mar.2011 at 11:39
why background publishing is not working in my system, I am using 2011,
I enabled publishing but it not taking, what is the problem?
otil
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Mar.2011 at 11:48
otil: You do realize you're using someone else's thread to post your own question don't you?
What have you done to troubleshoot the problem so far?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,137 seconds.
