Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
sridhar.m20
Newbie
Joined: 19.Oct.2010 Location: India Using: Autocad 2012 Status: Offline Points: 2 |
Topic: CGPosted: 12.Sep.2011 at 11:16 |
HOW TO FIND CENTER OF GRAVITY OF ASSEMBLY IN AUTO CAD.
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 12.Sep.2011 at 11:47 |
I thought assemblies were specific to Inventor. To my knowledge AutoCAD does not use/construct assemblies.
It is possible to find the center of gravity of a 3Dsolid in AutoCAD using a custom lisp routine. I've seen one or two around at various AutoCAD Help websites. |
<<AutoCAD 2015>> |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2165 |
Posted: 12.Sep.2011 at 11:58 |
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1521 |
Posted: 12.Sep.2011 at 12:50 |
Hello, with your 3D solids you don't have to "union" them to read the properties of an assembly with the command "MASSPROP".
Select the various elements and read the properties of the assembly.
You will have the properties in the following sequence :
Mass : in your unit with a density of 1 ( x 7.85 for steel )
Volume : in your unit
Xxxxxxxx : external dimensions
CENTER OF GRAVITY : in your unit
etc...
Use the informations with your F1 button on your keyboard to analyse the informations that you get.
Beware of the units.
If you whant to get the inertias about X and Y, you will have to set an UCS position at the center of gravity before reading the values.
sridhar.m20
Newbie
Posted: 12.Sep.2011 at 15:15 |
GREAT .. QUIET AN ANSWER ,I HOPE THAT WOULD DO IT.
THANKS.. |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,070 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
CG
Topic Options
