RSS discussions
Discussion Discussion forum
Topic ClosedTool Palette
 Post Reply Post Reply
Author
ACAD76 View Drop Down
Newbie
Newbie
Using: AutoCad2009
Status: Offline
Direct Link To This Post Topic: Tool Palette
    Posted: 22.Aug.2012 at 21:18
Dear all,
I would kindly ask for your assistance please.
My computer has already been set-up in a way to incorporate tool palette with defined symbols, blocks etc.
I would like to add title blocks.
how can I do that?
Thanks
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 00:10
Create a new tool palette and populate it with your title blocks.
<<AutoCAD 2015>>
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 10:20
In order to save something to a Tool Palette you must be in a saved drawing.  So open a drawing that has the title block(s) in it you want on a Tool Palette... ideally this would be from one of your title block template drawings.
Open the Tool Palettes on your screen and right-click the Tool Palettes - All Palettes gray title bar.  Click on New Palette and name it.  Now select your title block, pause a second (you can't click and drag all in one step for this to work), and then click and drag the title block to your new palette.
On the palette itself you can right click the new icon and modify its properties.  You can name it, specify what layer it should go on, rotation, any number of things.
This should get you going.  From here spend a little time in the AutoCAD files reading about other aspects of using Tool Palettes.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Newbie
Newbie
Using: AutoCad2009
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 22:37
Dear all,
Your prompt feedback is greatly appreciated.
Please note the following...
My intention is to create autocad tool catalog with blocks of interest , put it in the folder referenced in Options/file tab/Tool Palettes file location/(link to the folder where Acad tool catalog is placed). In this way, Tool Palette will be populated with blocks of interest.
Do you agree?
The question is how to create Acad tool catalog from blocks in dwg format of interest.
Thanks
Back to Top
Newbie
Newbie
Using: AutoCad2009
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 22:41
Thanks for your reply.
Any thoughts on the following...
I want to create ACAD Tool catalog (with blocks of interest) , put it in the folder and reference this folder in Tool Palettes file location. In this way, tool palette will be populated with blocks of interest.
Do you think this might work instead of pick&drop blocks in tool palette.
The question is how to create ACAD Tool catalog file with blocks in dwg format?
Thanks
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 23:51
Let's say you already have all the blocks saved as either individual DWG files or combined by type in one single block file DWG somewhere.  As long as they've been saved on your system somewhere you can always load the file and drag and drop the blocks onto Tool Palette tabs organized as you like.
That's actually what I've done for myself.  I have one large file of standard blocks.  I simply load that and drag the blocks onto various tool palette tabs.  From there I can modify the block properties so they go in on the correct layers, etc.
Your individual blocks can be WBLOCK written out as individual DWG files, or saved in one large file.  The choice is yours.  But putting frequently used blocks on tool palettes is a tremendous time saver.
Dave.
Dave Hein, P.E.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,121 seconds.
