Discussion forum
CAD discussion |
(Noob asks): drawing axis doesnt change w/ view? |
Post Reply | Page <12 |
Author | |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 09.Jul.2015 at 00:57 |
You might want to either buy a book or look in AutoCAD Help.
<<AutoCAD 2015>> |
John Connor
Posted: 10.Jul.2015 at 11:32 |
Upload a copy of the drawing to this website or make it available through Dropbox. Someone will take a look at it and suggest a solution to your problem.
<<AutoCAD 2015>> |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1434 |
Posted: 10.Jul.2015 at 15:51 |
SEANT
Groupie Joined: 09.Jan.2012 Location: United States Using: AutoCAD 2016 Status: Offline Points: 31 |
Posted: 12.Jul.2015 at 12:15 |
Is the problem that the Restore Ortho setting has been set to "No"?
The this Autodesk Screencast - At first, I have the restore Ortho set to "no", Then I re-set it to yes to get the "out of the box" default: |
SEANT
Posted: 12.Jul.2015 at 12:36 |
[QUOTE=SEANT]
Is the problem that the Restore Ortho setting . . . .[/QUOTE]
or, more specifically, the UCSORTHO system variable.
Tweet
This page was generated in 0,543 seconds.
