RSS discussions
Discussion Discussion forum
Topic ClosedReplacing Blocks
 Post Reply Post Reply
Author
rushy24 View Drop Down
Newbie
Newbie
Using: ZWCad
Status: Offline
Direct Link To This Post Topic: Replacing Blocks
    Posted: 01.Aug.2014 at 23:59
I've got a drawing of a city map containing street lights as blocks.  My goal is to assign a number to each pole.  My first thought was create a new block with an attribute and then simply replace all the others with the new one.  Seems I can't replace a block with a block that has attributes.  Anyone have a suggestion as to how I can accomplish what I'm after?  Thanks in advance!
Back to Top
Newbie
Newbie
Using: ZWCad
Status: Offline
Direct Link To This Post Posted: 02.Aug.2014 at 00:26
After searching around, let me rephrase this.  Apparently this may have been imported from another program way back when.  So for these street light blocks, I really have about 800 of the same blocks named ST_1 through ST_800.  This drawing just seems to need cleaned up, greatly!  It's the same case for other blocks, such as fire hydrants, water valves, pole lights, sewer drains...etc.!  Anyone help?  It seems like it may be a very time consuming fix having to go one by one
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2014 at 12:24
Sounds like a task best suited to a custom lisp program.  Question is, does ZwCAD support lisp?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: ZWCad
Status: Offline
Direct Link To This Post Posted: 02.Aug.2014 at 14:58
Yes, it does. I run a few already.
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 05.Aug.2014 at 08:12
There is no problem with replacing blocks with attributes in AutoCAD. You can then use our InsertC/BlockC utility (see Download) to automatically renumber the blocks (fill their attributes).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,149 seconds.
