RSS discussions
Discussion Discussion forum
Topic Closedhelix
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: helix
    Posted: 26.Sep.2014 at 14:57
An example of a 3D spring created using the HELIX command.
Diameter=2
Height=8
Turns=20
Circle radius=.125
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 26.Sep.2014 at 14:53
There isn't much work involved in creating a spring using the helix command.  First create the helix, next draw a circle, then invoke the SWEEP command.  Pick the circle as the object to sweep and the helix as the path to follow.  Done.
What visual style are you using?
Did you see any error messages on the command line such as this:
Modeling Operation Error:
     The sweep results in a self-intersecting body.
Unable to sweep 1 selected objects.
If so then the diameter of your circle was too large or the spacing of the turns on your helix were too close together thus causing the swept circle to intersect itself which then results in the modeling operation error.
Edited by John Connor - 26.Sep.2014 at 14:54
<<AutoCAD 2015>>
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 26.Sep.2014 at 07:21
Hello purti, your commands are OK to have a 3D spring with HELIX and then SWEEP.
With helix you draw the centerline of your spring and then you have to draw a circle of the diameter of your spring wire that you will sweep along the helix.
Press the F2 button  and read the error message that you will get if nothing happens when lauching a command.
Send us a file so that we can take a look at it.
I have AutoCAD Mechanical 2012 and it should be OK.
With that release you can even draw a sping with a non circle wire.
Eventually take a look at my file : 3D SOLIDS 01.dwg that you can find in the CAD Blocks library.
You can also read the CAD Forum Tip N° 836 with direct access here : How to draw a 3D spiral in AutoCAD
Edited by philippe JOSEPH - 26.Sep.2014 at 07:39
Back to Top
purti View Drop Down
Newbie
Newbie
Using: AutoCAD 2D, 3D 2014
Status: Offline
Direct Link To This Post Posted: 26.Sep.2014 at 03:59
I have some problem to create spring in 3D (basically spring wire diameter). i used helix and then sweep command. as per i search. but nothing was happen i need spring in my design.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
