RSS discussions
Discussion Discussion forum
Topic ClosedModification of Dim Comand
 Post Reply Post Reply
Author
rdruillet View Drop Down
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Topic: Modification of Dim Comand
    Posted: 27.Feb.2015 at 21:41
HI EVERYBODY, long time ago (in 2004 version) I went from 2004 to 2014 in one jump. I had modified the dim command to send him to the dim layer, before putting a dim. I lost the info, and can't find it. If somebody has it can you please help me.
I went from 2004 to 2014 in one shot.
Ricardo Druillet
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 22:24
Can we assume that your template file already has a dimension layer included?  Should that be the case then at least the modification won't have to make the layer first.
Which dim command are we talking about?  DIMLINEAR?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 22:29
Hi John, I just want to make the dim layer the current layer before putting the dimension, that way it saves one step. It was done in the macro of the command, I just can't remember the sintaxis.
Thanks
Ricardo Druillet
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 22:31
Which dim command?  There are several.  DimLinear, DimAligned, DimAngular, etc.  All or one?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 22:35
it works for all of them, it just have to be inserted in the macro before the actual command, it goes between ^C^C and "dimaligned"
Ricardo Druillet
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 22:39
Edit the CUI and add the -layer command, set, and your layer name.  Don't forget the dash.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Posted: 27.Feb.2015 at 23:03
thanks, I will try it.
Ricardo Druillet
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
